parasti (veca tipa) atslegas ir 3. Viena skaista sarkana ar tabu mikstu AR embleminju ieksa - to jalieto ikdienaa.. Otra ir tada pati sarkana plastmasa, tikai nav skaistas embleminjas viduu... ta ja nemaldos bija servisa atslega... tresha tada necila kantainu galu, parasti bordo krasa - ta ir visu atslegu atslega - Master key. ar sho tad ari var veikt visas tas parprogramesanas darbibas
| Thu Nov 08, 2007 9:34 am |
Angliski Master key saukā par "Burgundy key" (krāsas dēļ, protams)
| Thu Nov 08, 2007 9:37 am |
shadow_man
Pievienojies: 08 Aug 2007
Komentāri: 310
Atrašanās vieta: Rīga, Imanta
The 156/147/GT range NEVER came with the old master key system.
Early 156 came with two identical red keys (both remote)
Later 156 came with two identical black keys (both remote)
| Thu Nov 08, 2007 11:39 pm |
shadow_man rakstīja:Servisaa man saka ka vagagot kaut kaadu 3 atsleegu lai taa mashiina ietu
kas taads par servisu? taa teorija taada ... diivaina
| Fri Nov 09, 2007 12:20 am |
shadow_man
Komentāri: 310
Tici man, tur viss saak palikt diivaini, tas serviss nav riigaa...
Cilveeki it kaa visu laiku njemas ar itaalju autinjiem, bet ar maneejo kaut kaa nesanaak..
Kompja uzraadija kljudas":
*Galvenais relejs(!!!)
*Aizzdedzes atsleega
*Pechkas 1,2 aatrums
Nodzeesa, bet nekas nemainaas. Tagad jau alfa prasa kodu ievadiit, pec kodu ievadiishanas 2 reiz varot pielaist un viss.
Degviela, ieleeju neStatoil un neNeste?? man jau depresija saakas, bez ritenjiem kaa bez rokaam..
| Fri Nov 09, 2007 8:55 am |
shadow_man
Komentāri: 310
Varbut kaadam noder:
Alfa Diagnostics (CODE system)
Turn the key to Marcia (ignition lights etc)
Fully depress (to the floor) the accelerator five times within five seconds and fully release.
The code should come up more or less straight away.
The injector light will flash up a code to indicate the fault…
4-4-4-4 - no errors
1-2-1-1 - battery voltage
1-2-1-4 - engine temperatue sensor
1-2-1-6 - throttle valve sensor
1-2-2-1 - air flow meter
1-2-2-2 - idle actuator (opening)
1-2-2-3 - regulation of lambda probe
1-2-2-4 - heated lambda probe
1-2-2-5 - air temperature sensor
1-2-2-6 - electroinjectors (group 1)
1-2-3-1 - power ciruit (inside control unit)
1-2-3-2 - electroinjectors (group 2)
1-2-3-3 - idle actuator (closure)
1-2-3-5 - compressor inlets
1-2-3-6 - compressor command
1-2-4-3 - fuel pump relay
1-2-4-4 - vapour recovery solenoid valve
1-2-4-5 - timing variator relay (1.8 and 2.0 TS only)
1-2-5-1 - control unit EPROM
1-2-5-4 - throttle valve sensor (signal
| Sat Nov 10, 2007 1:04 pm |
shadow_man rakstīja:Varbut kaadam noder:
4-4-4-4 - no errors
shie kodi attiecas tikai uz 155, 156 iipashnieki mieriigi var nespaidiit pedaali, nekas nebuus!
| Sat Nov 10, 2007 2:14 pm |
Un tikai uz Motronic 1.7 (8v)
| Sat Nov 10, 2007 4:00 pm |
164 8v
155 8v ~ap 1994-1995 gadu
Nu tipa - Altez 155 tas darojas.
| Sun Nov 11, 2007 12:12 am |
shadow_man
Komentāri: 310
 Beidzot!!
Ko lai saka, esmu atkal uz ritenjiem, Alfinja iet!! Vaina bija signalizaacijaa, elektriiba prieksh signalizaacijas panjemta no mashina kompja, kaa rezultaataa saaka truukt kompim elektriibas un liidz ar to alfa negaaja. Vadi tur esot sagriezti, un signalizaacijas vadi pietiiti ne salodeeti  CIk ilgi signalizaacijai ir garantija?? Jaabrauc uz to kantori un jarok aaraa kara cirvis. Tas jau viss po, galvenais ka iet un atkal areeshu atkal korkjos staaveet
| Wed Nov 14, 2007 9:25 pm |
Krizis
Pievienojies: 05 Apr 2007
Komentāri: 239
Atrašanās vieta: Ādaži
 Re: Beidzot!!
"Arneo", SIA, Auto signalizācijas, Mūkusalas 45/47, Rīga, LV-1004
NEIESAKU APMEKLĒT ŠO KANTORI UN IZMANTOT TĀ PAKALPOJUMUS!!! Nejēdz kvalitatīvi veikt savu darbu - tas attiecās uz konkrēto gadījumu
_________________ Atkal gribu alfu...
| Tue Jan 29, 2008 10:46 am |
 Re: Beidzot!!
Krizis rakstīja:"Arneo", SIA, Auto signalizācijas, Mūkusalas 45/47, Rīga, LV-1004
Paldies zināsim, bet es pārdaugavu neapmeklēju pēz definīcijas  Lai viss strādā
| Tue Jan 29, 2008 10:50 am |
supinator
Pievienojies: 27 Apr 2007
Komentāri: 157
Atrašanās vieta: Jūrmala
xls99 rakstīja:parasti (veca tipa) atslegas ir 3. Viena skaista sarkana ar tabu mikstu AR embleminju ieksa - to jalieto ikdienaa.. Otra ir tada pati sarkana plastmasa, tikai nav skaistas embleminjas viduu... ta ja nemaldos bija servisa atslega... tresha tada necila kantainu galu, parasti bordo krasa - ta ir visu atslegu atslega - Master key. ar sho tad ari var veikt visas tas parprogramesanas darbibas
Man 146 arī līdzīgi,3 atslēgas, divas aizdedzes un 1 brūna kautkāda remont.Uz brūnās ir kaut kas līdzīgs pogai,pie auto ieg;ades man teica to atslēgu izmantot tikai motora probl;emu gadijumā.Varbūt kāds var pateikt vairāk?
| Thu Feb 28, 2008 1:02 am |
brūnā ir Master key.
Ar to var programmēt jaunas (blank) sarkanās.
Read da manual.
P.S. braukt ar brūno arī var, tikai nevajag to padirst.
| Thu Feb 28, 2008 1:09 am |
shadow_man
Komentāri: 310
Turpinam. Kādu laiku jau mocos ar to ka neceļ apgriezienus virs 3000. Ir tā ka ar pirmo ātrumu braucot, pedāli iespiežam grīdā, mašīna aiziet uz kādām 2 sekundēm un tālāk jau apgriezieni ceļas lēnām it kā vēl bremzes būtu nospiestas. Braucot ar 4 robu uzceļ lidz 120 km\h tad taho ir 3 tk rpm un viss, vairak neiet. 5 robā tas pats 3000 rpm 140 km/h un viss. Sajūta tāda ka kaut kas trūkst, liekas ka motors tūlīt izjuks. Jauda ir reāli kaut kur pazudusi. Visu laiku jabrauc 2000-3000 rpm diapozonā, savādāk neiet.
Kļūdas nekādas nav, diagnostika veikta ar 3 dažādiem kompjiem. Turbīna pūš. Lec no pus apgrieziena. Varianti?
| Sun Apr 19, 2009 2:25 pm |
