The Ulysse Nardin Freak S Purple Enamel reviewed: the final ti Freak S with an enameled surface hour disc, a guilloché-flinqué Donzé Cadrans dial, cal king silicon oscillators, and a 50-piece limitation.
The final chapter of an specific Freak S report
The Ulysse Nardin Freak has spent 25 years appearing that a watch does not need hands and fingers, a dial, or a prized in the conventional sense to become watch. The Freak S is the boldest expression of their concept: an automatic watch along with dual oscillators, a soaring carousel movement that swivels around its own axis, as well as approximately 95% of it has the components in constant motions 。The Freak S Purple Enamel is not just another color ways. It is the final Freak S in a titanium case to help feature an enamel hour or so disc, limited to 50 portions, and it closes a segment that began when Ulysse Nardin first combined typically the Freak's high-tech architecture together with traditional enamelling 。
This framing matters for debt collectors. The Freak S was already passed through turquoise blue and also ruby red enamel hr discs, each pairing precisely the same radical movement with a métiers d'art surface 。The Purple Enamel is the last titanium-and-enamel Freak S, which gives the item a defined position in the family tree rather than an open-ended “another variant” status.
perfect watches replica
high quality replica watches
replica jacob and co cr7 watch price
The dial that is not any dial: guilloché-flinqué enamel by Donzé Cadrans
The “dial” of the Freak S Purple Enamel is actually a rotating hour disc, and it is made altogether in-house at Donzé Cadrans, Ulysse Nardin's dedicated enamelling workshop 。The technique is guilloché-flinqué enamel: a white gold basic is stamped with a pattern-here, an in-house guilloché-style motif-then lined with semi-transparent purple enameled and fired repeatedly from around 800°C to achieve the closing depth and gloss 。The white gold base is not some sort of generic alloy. Ulysse Nardin specifies an 18-karat make up with 130‰ palladium, 120‰ silver, and 750‰ yellow metal, a ratio chosen to get thermal stability so the dvd can survive repeated kiln firings without warping 。
The result is not a flat purple surface. The guilloché structure sits beneath the translucent tooth enamel, so light passes over the enamel layer and discloses the engraved texture directly below, creating a sense of degree that a lacquered dial could not replicate 。Watchonista describes often the shade as closer to some fine wine than a glistening amethyst-regal rather than eye-grabbing, along with deliberately more subdued over a jewel-toned purple 。The ancient reference is apt: Tyrian purple was made from the mucus of roughly 10, 000 Murex snails per g, making it literally worth the weight in silver throughout antiquity 。The Freak Nasiums Purple Enamel is not employing purple as a trendy emphasize; it is using a color along with a long association with originality to frame a activity that is about as exceptional as automatic watchmaking obtains.
UN-251: twin oscillators, six planes, and a Grinder gathering system
The Caliber UN-251 is a self-winding movement using 373 components, 33 jewelry, and a 72-hour power reserve 。Its defining feature is the dual-oscillator architecture: two oversized oscillators inclined at 20 qualifications, each with a silicon sense of balance wheel, running at 2 . 5 Hz (18, 000 vph) per oscillator 。The two oscillators are hooked up by what Ulysse Nardin represents as the world's smallest top to bottom differential with ball bearings, which averages their fees and supports the stability with the system 。The Freak S is the world's first intelligent watch with dual oscillators, and the UN-251 runs down six separate physical aircraft, with 95% of it is components in motion for the wrist 。
Winding emanates from Ulysse Nardin's Grinder technological know-how, first unveiled in 2017. The Grinder system seemed to be purpose-built to meet the power requires of the Freak's carousel mobility while still delivering a new 72-hour reserve; it transforms even the slightest wrist movements into usable energy by low-friction ceramic ball bearings, feeding the low-frequency 2 . 5 Hz movement 。The architecture is deliberately contrary to a conventional automatic: there is no one in the traditional sense, plus the entire movement acts as the actual winding mass. This is why the particular Freak S looks like the machine hovering above the wrists rather than a movement tucked within a dial.
Wearing a 45 mm titanium carousel
Predicament is 45 mm with diameter and 16. 65 mm thick, in ti, with an open sapphire caseback and no conventional crown as well as dial 。The carousel supply suspends above the hour game, and because the movement themselves rotates, the visual practical experience is closer to watching any kinetic sculpture than examining a watch. Water resistance is 30 metres, which is consistent with the Freak's positioning as a mechanical discussion rather than a sports watch 。
luxury replica watches
swiss replica watches
replica Ulysse Nardin FREAK S PURPLE ENAMEL
The purple enamel hour disc is definitely repeated on the calfskin tie, tying the presentation along without making the watch sense that a color-block exercise 。At 45 mm, the Freak S is large and not absurd; the titanium scenario keeps the weight manageable, along with the absence of a bezel in addition to conventional lugs means typically the visual mass is concentrated inside sapphire-and-movement assembly rather than in the slab of metal. This isn't a watch for someone who wants some sort of subtle wrist presence, nevertheless it is also not a watch that will relies on size alone-the movement earns the attention.
Specification bio: Freak S Purple Enamel
Attribute Details Reference
2513-500LE-7AE-PURP/0A
Case diameter
45 mm
Thickness
16. 65 mm
Case material
Titanium
“Dial”
Rotating hour disc, guilloché-flinqué enamel on 18k white gold base, made by Donzé Cadrans
Movement
UN-251, self-winding
Oscillators
Twin inclined silicon oscillators, 20° incline, 2 × 2 . 5 Hz
Differential
Vertical differential with ball bearings
Components
373
Jewelry
33
Power reserve
72 a long time
Winding
Grinder system having ceramic ball bearings
The reason this matters beyond colour
The Freak S Blue Enamel is interesting given it puts two normally different watchmaking languages into the similar object. On one side: lesser sibling silicon oscillators, a usable differential, a Grinder hustleing system, and a movement in which runs across six air carriers with 95% of their parts in motion. One the other side of the coin: a guilloché-flinqué enamel time disc made by hand with Donzé Cadrans, fired on 800°C, and finished in a very shade of purple this carries centuries of links with rarity and status. The watch does not ask you to choose from high-tech and métiers d'art; it treats them seeing that equally valid ways of generating a mechanical object desirable.
To get collectors who have followed often the Freak S through it has the enamel variants, the Purple Enamel is the closing controversy: the last titanium Freak S with an enamel disc, limited to 50 pieces. For any individual new to the Freak brand, it is also a useful entry point in understanding why Ulysse Nardin's most radical collection features lasted 25 years-not as it is shocking, but because it continues finding new ways to make the identical radical idea feel resultant. If you are researching current market ranking, a Ulysse Nardin Freak S Purple Enamel , 400 as the reference point, with the 50-piece limitation doing most of the improve the secondary market 。For a watch that looks like a new spaceship, the most traditional process in the room turns out to be the one that causes it to become feel finished.
https://www.prowatchduo.co.uk
high quality watches replica
wholesale replica watches
