Izskatas labs tas stelvio. Strategija prezentet top versiju, kas ciparos izgriez pogas konkurentiem pec sajutam ari liekas laba. Liek potencialam premium pircejam padomat. Good good
Wed Nov 16, 2016 8:33 pm |
Starpcitu, pamanijat, ka tas chals kas prezenteja bija nochiepis dalju no uzrunas no Palaidnieka runas Autobrava  1:1
Wed Nov 16, 2016 8:34 pm |
xls99 rakstīja:Starpcitu, pamanijat, ka tas chals kas prezenteja bija nochiepis dalju no uzrunas no Palaidnieka runas Autobrava 1:1
Aha - tieši nodomāju, kurš viņam rakstījis runu ;D
Wed Nov 16, 2016 8:35 pm |
Citāts:The Q4 system's architecture includes an active transfer case and front differential designed to meet the specific technical requirements of Alfa Romeo, entailing the rapid-response management of high torque levels, with a compact, lightweight set-up. The transfer case makes use of advanced active clutch technology to deliver an outstandingly dynamic ride combined with good fuel economy.
In normal conditions, the Stelvio Quadrifoglio with Q4 system acts like a rear-drive vehicle, with 100% of the torque sent to the rear axle. As the wheels approach their grip limit, the system transfers up to 50% of the torque to the front axle via a dedicated transfer case. To modulate torque distribution with the utmost speed, the system uses a high degree of mechanical over-slip (up to 2.5%) between the two axles, which translates into class-leading control in terms of traction and directional stability when cornering.
Combined with Q4 all-wheel drive for the first time, Alfa Romeo's Torque Vectoring technology optimises the Stelvio Quadrifoglio's drive distribution and accentuates its sporting character. The two clutches in the rear differential make it possible to control torque delivery to each wheel separately. So power is transferred to the ground more effectively, even when you drive the car to its dynamic limits. This makes the Stelvio safe and fun to drive at all times, without recourse to intrusive inputs from the stability control system.
Neko nesapratu, pakaltilta divsajugu difts, tatad blokis, razdataka ir "aktivais sajugs", kas tas tads? Prieksejais laikam ir parastais valejais difs. Dodot rucka vismaz tris riteni griezisies, kas salidzinot ar parketnieku parasto ir riktigi kruta
http://www.alfaromeopress.com/press/article/world-preview-alfa-romeo-stelvio
Wed Nov 16, 2016 8:46 pm |
dima.a
Pievienojies: 19 Apr 2010
Komentāri: 659
Fantastiski smuka mašīna!!! Visādi Macani/Cayenni, Jaguari/Bentley un Bmw X/Audi Q vienkarši atpūšas!!!
 bravo,bravo!!!
Wed Nov 16, 2016 8:56 pm |
Pat ņemot vēra to, ka man SUVi ka tādi īpaši neuzrunā!
Thu Nov 17, 2016 12:17 am |
Pirmaja momenta ta ka nepamaniju, bet kad ieskatas labak Stelvio loooti atgadina Maserati Levante. Virsbuves aprises ir vienadas.
Atskiriba ir detaljas, durvju, sparnu ieliekumi savadaki, kapots savadaks, reste, buferi savadaki, lampas savadaki. Kopuma Alfa skaistaka.
Maserati savu bobiku var dzit muzeja un aizmirst ka neizdevusos projektu.
Thu Nov 17, 2016 7:44 am |
dima.a
Komentāri: 659
Thu Nov 17, 2016 11:10 am |
piektdienis
Pievienojies: 15 Dec 2013
Komentāri: 6
Atrašanās vieta: jelgava
Thu Nov 17, 2016 11:01 pm |
Liekas, ka alfisti visā pasaulē mainīs orientāciju un no pilnīgiem SUV noliedzējiem , kļūs par to mīļotājiem
Fri Nov 18, 2016 3:08 pm |
krods
Pievienojies: 04 Feb 2015
Komentāri: 618
Fri Nov 18, 2016 3:13 pm |
dima.a
Komentāri: 659
Fri Nov 18, 2016 3:26 pm |
rixis
Pievienojies: 19 Mar 2014
Komentāri: 171
2000 Alfa-Romeo 145
Tāpat, kā kādreiz nemīlēja Vettel'u
Mon Nov 21, 2016 8:00 pm |
Par ko Vettelu milet?
Mon Nov 21, 2016 10:56 pm |
arba rakstīja:Liekas, ka alfisti visā pasaulē mainīs orientāciju un no pilnīgiem SUV noliedzējiem , kļūs par to mīļotājiem
tad to lamatu ir šausmīgi jāsēdina
Tue Nov 22, 2016 9:52 am |
