AR mani
Pievienojies: 14 Sep 2006
Komentāri: 30
 kāda būs jaunā 166?
Čau visiem. Vai kādam ir kādas vīzijas, noderīga infa, vai saites kāds būs 166 alf. Paldies.
| Tue May 08, 2007 2:21 pm |
| Tue May 08, 2007 2:34 pm |
tu droši vien domā 169
| Tue May 08, 2007 2:35 pm |
yuran
Pievienojies: 18 May 2007
Komentāri: 2339
1984 Alfa-Romeo GTV6 2,5
| Fri May 18, 2007 11:02 pm |
shiis bildes jau kaut kad februaarii paraadiijaas, kopsh taa laika nekaadu jaunumu nav, pat Zhenevas autosalona nebija nekadas informacijas. ka tik projekts nav iebukseejis
| Fri May 18, 2007 11:18 pm |
Bāc. Šitais varētu būt reāls konkurents BMW 5/7series, Mershiem un Lexusiem.
Baigi jācer ka viņi tomēr nav nostopējuši šo projektu un ka šis būs instruments ar ko AR atkal ieies ASV tirgū (par ko itkā mums po, bet tas nebūtu slikti).
Citāts:The 169 will have dimension similar to those of the CLS: 4,95 meters long, 1,4 meters hight. New gearboxes from Getrag are expected (including a 7 speed dual clutch). Under the hood it's strictly a V6-V8 party: gasoline engines start from the 2.8 V6 (250 hp) and go on to a 3.2 V6 (285 hp) and a 4.3 V8 (400 hp and 500 Nm). The 3.0 V6 turbodiesel should have 275 hp and 620 Nm.
Prices should start a bit under 50.000 € for the 2.8, grow to about 50.000 € for the 3.0 diesel e go up to 75.000 € for the 4.3 V8. The hypothetic GTA 5.0 V8 (more than 500 hp) should cost about 100.000 €.
| Fri May 18, 2007 11:23 pm |
Kas ta par peleko breras vieta alfistu.lv sakumlapa ? 169?
| Wed May 23, 2007 2:42 am |
Tas ir kaads AR Speis shatls.
| Wed May 23, 2007 9:01 am |
| Wed May 23, 2007 10:37 am |
izpīpēji Javascriptu Smic
| Wed May 23, 2007 10:38 am |
Vilks
Pievienojies: 21 Jul 2006
Komentāri: 179
1999 Alfa-Romeo 156
| Fri Jun 01, 2007 5:32 pm |
Jauna? Veca!
| Fri Jun 01, 2007 5:55 pm |
Peec ~0.5 sekundeem pirmajam roljikam man bij skaidrs, ka tas ir FL, ko nesen paartrauca razhot  Cerams, ka 169 (what a magic numba!) purns buus smukaaks.
| Fri Jun 01, 2007 6:04 pm |
j.k. rakstīja:izpīpēji Javascriptu Smic
ir tak poga Print screen
| Fri Jun 01, 2007 6:06 pm |
MartinsT rakstīja:j.k. rakstīja:izpīpēji Javascriptu Smic
nē viņš ielika linku uz source failu, tā kā nekāds printscreens tur nav.
| Fri Jun 01, 2007 6:09 pm |
