Atbildēt pie šī temata 4 lapa no 42 lapām pavisam
Iet uz lapu Iepriekšējais  1, 2, 3, 4, 5 ... 40, 41, 42  Nākošais
Palidziet, iesacejam alfistam!
Atraak ka nakoshnedeelj nesanaaks...  Sad  Nav nevienam tas variators.
Mlje... pie sashas gandriiz uz pusi leetaaks kaa A-italiaa. Divreiz variet mineet no kaa es pirkshu! Laughing
pratigais rakstīja:
Tad jau pie reizes arii siksnas un rulljus vareetu nomainiit ne? Cik sapratu, tad tur demontaazha taada pati nepiecieshama...
10k atpakalj mainiju... nedomaju ka vajag tagad.
kur mainīji siksnu, un kurš p. neteica, ka vajag pie reizes arī variatoru nomainīt?
pratigais rakstīja:
Ir tāds plaši izplatīts uzskats, ka variatora nomaiņa pilnīgi neko neietekmējot... protams neskaitot traktora pieskaņu.
pratigais rakstīja:
Mainiju sono! Sad
Bet palasot 156.net man gan neliekas ka tas maina tikai skanju:
There has been quite a few issues with "diesel-noise" from the Twin Spark
engines. The "diesel-noise" will in the beginning last only a few seconds
after turning your key to start the engine. But it will last longer and
longer. The "diesel sound" does not have to be quite noticeable as it is the
first few seconds after turning the key. An ok engine should not have any
diesel sound at all, even at cold start!
It's a typical failure of the so called "variator" that regulates the
camshaft timing over the full rpm-range. If damaged it means loss of
"top" power, even less power under 3000rpm and higher fuel consumption.
No matter how old your car is, it is always a "hidden fault". Under
the consumer protection laws valid in Europe it will remain guarantee
for many years.
There should be no problem driving with this, you will not damage
anything, but it should eventually be fixed. In Norway I have heard
that this is fixed on warranty and Fiat even pay a part of the price
if the car is off warranty.
The reason for this is many cold starts and driving short distances.
This is because the variator need oil to get its work done, but after
a cold start it takes some time to get the oil in this variator. This is
a poorly constructed part and has been replaced by a new part with
the part number: 60666199
All new Alfa's since April 2000 have this new variator. The "old" one came
from 2 sub suppliers of which 1 made a bad product. Anyway, your dealer
should know; is was one of there nightmares in 1999/2000.
You can also give your variator a better life if you change oil at least
every 10.000 km (which is recommended anyway).
Es jau neko. Bet vairāki "sentēvi" to ir teikuši. Nezinu vai pamatoti vai nē... Smile
jāmaina pat ja tas neko nemaina - taču piegriežās. tāpat kā ar tām čīkstošajām šarām vai ko tur......IMHO
ti že ņe golf kupil (c)nezinukuram
Arfilaa ar man ta teica... bet nu spriediishu tad kad nomainiishu.  Wink
Pa cik nāk tas variators?
pratigais rakstīja:
Visdrīzāk tad arī no Sašas šī atziņa ir aizceļojusi līdz daudzu alfistu ausīm...
pratigais rakstīja:
kad mainīju zobsiksnu, Saša ieteica nomainīt, kas arī tika izdarīts. ja kautko galīgi neputroju kautkas ap 50-60 Ls varēja būt...
Cenas tur ir slidenas! Very Happy  Razz
vienai mashiinai variatoru esmu mainiijis. iznjemot skanju nekas cits neizmainiijaas. labaak negaaja, degvielu mazaak neteereeja. otrai un treshai vairs nemainiiju. tad atteicos no vinjiem vispaar shura
 Sad  Sad  Sad
To4 nekaa?
Bet vienalg ta skanj besii... tracina! Mad
Kas ir variators un ko tas dod,ietekmē utt????
vilsons rakstīja:
Paskrollē uz augšu tur ar sarkaniem burtiem angļu mēlē pagarš citāts...
