What Is FT Betting? Tips for Accurate FT 1×2 Betting
If you’re into sports betting, chances are you’ve come across FT betting before joining the action. Although it may sound unfamiliar at first, anyone entering the betting scene will eventually hear about it. If you’re still unsure, let win tips bet walk you through the essential information to fully understand what FT betting means!
What Is FT Betting in Football?
What is FT betting?
In football, FT stands for Full Time, meaning the entire duration of the match. The official playing time, excluding injury time, is 90 minutes. This English term was quickly adopted into the Vietnamese betting scene. FT simply means "Full Time," referring to the period when players are actively on the field during both halves of the match.
In FT Handicap betting, players predict the outcome across both halves of a particular match. Many players opt for HT (Half Time) betting for faster results and quicker payouts, moving on to the next round sooner.
However, with FT betting, you get to observe the entire match and create greater opportunities for a significant win. Of course, the potential rewards are also much higher depending on the online bookmaker.
Should You Bet on FT?
What is FT betting?
According to statistics, players only have about an 11% win rate when participating in FT bets. Generally, for seasoned and experienced bettors, FT is considered a risky and high-stakes bet.
However, for those who truly understand beautiful female soccer players and grasp the dynamics of FT betting, it becomes an extremely attractive option with high winning potential.
[img]https://lh7-rt.googleusercontent.com/docsz/AD_4nXd0GSovgkMsDLSwasWSWcO09KqzGVsT30_cvd7yvqPbJdynTyEaxYL52gbZHUTrh9xYxG2SEyo_ttq0HOcYbGaKqK7NqvwldALb8tvE7b4kd6Z_bDW19r2FNlFbFsXrHyaWhYRFgQ?key=fj16m3XD-xVaTndzQDeYgA[/img]
Compared to regular betting markets, FT bets usually offer higher stakes and much bigger rewards. Thus, even without needing to wager huge amounts, you can still aim for large payouts.
That said, if the match ends in a 0–0 draw, your stake will either be refunded or fully settled according to the bet conditions.
When Should You Place FT Bets?
After learning what FT betting is, you should consider placing or reducing your FT bets under the following circumstances:
When one team has a weak defense and often concedes goals, while the other team dominates early in the game. However, the match dynamics might change in the second half.
Sometimes, a weaker team might lose in the first half but successfully mount a comeback in the second half. In such cases, you’ll need to adjust your bets based on the weaker/stronger team strategy.
Similarly, if a weaker team leads at half-time, but the stronger team regains control and wins by full time, strategic betting adjustments are crucial.
If a strong team gains an early advantage but then plays carelessly, exposing vulnerabilities, you can also place bets accordingly.
In crucial knockout matches, you might consider betting on a Draw (DD). If the match ends 0–0, you’ll receive a payout according to your bet.
The above information answers the question, "What is FT betting?" for those involved in football betting. It’s a familiar and popular bet type chosen by many. However, to maximize your chances of a big win, always make sure to research carefully before placing your bets.
Fi88 wishes you success and good luck!
