What Is Correct Score Betting? How Much Do You Win with a “1
Komentārs What Is Correct Score Betting? How Much Do You Win with a “1
What Is Correct Score Betting? How Much Do You Win with a “1 Bet” at Online Bookmakers?
For those who are passionate about online football betting, the term correct score betting is surely no longer unfamiliar. But for beginners just dipping their toes into the world of betting, questions like “What is correct score betting?” or “How much do you win with a ‘1 bet’?” are quite common. So in this article, let’s dive into the details with win tips bet to better understand this betting option.
What Is a Football Correct Score Bet? How Much Do You Win with a 1 Bet?
Explanation: What Is Correct Score Betting in Football?
Correct score betting—often casually referred to by bettors as “betting on the score”—is a type of wager where you place a bet on the exact result you think the match will end with. It’s a relatively straightforward type of bet and easy to understand, making it suitable for most beginners.
This type of bet requires players to predict the exact final score of a skinniest footballers within the standard 90 minutes of play. If you guess the correct score, you win the bet. If your prediction is wrong, you lose the entire stake.
In reality, predicting the exact outcome of a match that hasn’t yet been played is no easy feat. Even in cases of potential match-fixing, setting up a specific final score is incredibly difficult. Therefore, if you want to win a correct score bet, you’ll need to gather as much relevant information about the match as possible.
For example: insights into the teams’ current form, lineup, injuries, tactics, the venue, weather conditions, etc. Experts use these variables to make predictions that can carry up to a 65% winning probability.
How Much Do You Win from a 1 Bet on Correct Score at Reputable Online Bookmakers?
A common question among bettors is: How much can I win from a 1-unit bet on the correct score at trusted bookmakers?
The payout for a correct score bet depends heavily on the result you choose. The more unlikely the predicted score, the higher the payout multiplier.
[img]https://lh7-rt.googleusercontent.com/docsz/AD_4nXcu1d7Wt3wmxr6ODhtLoJ3gUhvOYQ0ut_Wvfbg7F0ewHk83aCc2-zbtB6P_an_wIKU3ZGjKJzjjjLzuKWcAMM9ipClLID_IpjHmiCgmJ1xUoLUqe1y-EHo5CE76do7Oc6O5Qf4P?key=fj16m3XD-xVaTndzQDeYgA[/img]
Let’s go through an example to help illustrate:
In a match between Russia vs Finland:
If you bet on a 1-0 scoreline, and the odds are 4.8 -> Your winnings=4.8 × your stake.
If you bet on a 0-2 scoreline, and the odds are 6.0 -> Your winnings=6 × your stake.
And so on...
How to Calculate Winnings from Correct Score Bets
Simply multiply your stake by the odds offered for that specific scoreline. The result is your total return if the score you predicted turns out to be correct.
Effective Tips for Beginners Betting on Correct Scores
Correct score bets usually offer high returns, but they're also among the hardest bets to win. In many cases, the actual match outcome doesn’t fall within the list of scores provided by the bookmaker ranking. That’s why many bettors play correct score bets more for fun or as a test of luck, rather than using them as a core betting strategy.
Odds vary across different bookmakers, so if you want to find the best value bets, you should compare odds between different platforms and choose the one offering the highest return for your chosen score.
Expert Tips for Betting on Correct Score Odds
According to experienced bookmakers, although the payout for correct score betting is attractive, winning consistently is very difficult. Therefore, to increase your chances:
Place bets on multiple scorelines in the same match with equal stakes. A safe approach is to spread your bets across 3–4 different likely outcomes.
Narrow down your score predictions using relevant data like team form and historical performance.
For Example:
If both teams have poor scoring records and solid defenses, likely scorelines include: 0-0, 0-1, 1-0, 2-0, or 1-1.
If both teams are strong offensively and tend to have high-scoring games, you might consider: 2-2, 3-1, 3-2, or 2-3.
In knockout stages of major tournaments like the Champions League, Europa League, or finals, goals are usually limited due to high stakes. Common results might be: 1-1, 1-0, 0-1, 2-1, or 1-2.
Final Thoughts
This article has broken down the details of correct score betting and answered the common question of how much you can win from a “1 bet.” Hopefully, it has helped you better understand this exciting but risky betting market so you can estimate your potential returns accurately. Good luck and happy betting!
