| Autors | Ziņojums |
	| Hindo Member of
			Komentāri: 2000
			Atrašanās vieta: Rīga/Ķekava
			elbee rakstīja:jaasatreneejas un taisam machus!
Njā, tikai jānopērk apļu skaitītāju, realitātes izjūtām - tribīnes un tehniskos cilvēciņus un, protams, visāda tipa antispārnus, motoriņus, stiprākus un vieglākus magnētus. Tad jau var dot vaļā pa nopietno!    _________________ SPecial Executive for Counter-intelligence, Terrorism, Revenge and Extortion		 |
	| Sun Feb 01, 2009 7:03 pm |     |
	| j.k. Member of
			2005  Alfa-Romeo  156GTA
			Es tā saprotu ka http://tinyurl.com/cxnza5  arī der SCX trasei...
Put yourself in a corner and find a way out!		 |
	| Sun Feb 01, 2009 7:17 pm |     |
	| elbee Member of
			kaads zinaataajs vareetu pastaastiit par mashiiniiteem. uz shitaas SCX trases kaadas mashiinas der? ko vinjaam tuuneet var? kaadi buutu vajadziigi noteikumi?
cik es saprotu, doma ir , ka katrs pats sev buvee mashiinu, ar ko satarteet    |
	| Sun Feb 01, 2009 7:25 pm |     |
	| j.k. Member of
			Te par SCX labi uzrakstīts:
http://www.hotslots132.com/scx-a-22.html?osCsid=a9b95fbc99e94fac09b475e53f42910b Citāts:The metal track rails have the strongest magnetic adhesion of any track in the market, and SCX track is compatible with old SCX or Scalextric "Classic" track that goes back over 40 years – in case you have old track that you would like to continue using.
 Citāts:Q: Will all 1/32 slot cars work on any brand slot car track?A: Yes, all modern, readily available 1/32 slot cars will work just fine on all readily available slot car track. Of course, if you want to run 1/24 scale cars you'll have to buy Carrera track. It is the only home track that is wide enough to accept the large 1/24 scale slot cars.
	| Sun Feb 01, 2009 7:39 pm |     |
	| ralfins Member of
			elbee rakstīja:kaadi buutu vajadziigi noteikumi?
...man bij pārs idejas - mēģināšu pa nākamo nedēļu izklāstīt nolikuma variantu...
P.S...bļe mirstu...    |
	| Sun Feb 01, 2009 8:15 pm |       |
	| yuran Member of
			Pievienojies: 18 May 2007
			Komentāri: 2339
			1984  Alfa-Romeo  GTV6 2,5
			Mļe, alkonafti      Žēl ka man bija jābrauc prom     [/list]
			 _________________ GTV6		 |
	| Sun Feb 01, 2009 9:35 pm |     |
	| lāča_kungs Member of
			Pievienojies: 04 Sep 2007
			Komentāri: 2329
			Pasākums ir izdevies, mums patika
Paldies Hindo, bildes megajautras
Atklāts ir, tagad vien jānovēl izturību, veiksmi un saules mūžu
	| Sun Feb 01, 2009 9:46 pm |     |
			Komentāri: 2329
			Lienii rakstīja:es ar Hindo esam vienisprātis - vislabākā ir pati pēdējā bilde!
	| Sun Feb 01, 2009 10:02 pm |     |
	| NIKSONS
			Pievienojies: 10 May 2007
			Komentāri: 4423
			2012  Alfa-Romeo  voyager
			Dzīvnieki     |
	| Sun Feb 01, 2009 10:23 pm |     |
	| elbee Member of
			j.k. rakstīja:all modern, readily available 1/32 slot cars will work just fine on all readily available slot car track.
tad atliek tik izveeleeties
   ebay no 20ls
   no 25ls
un shitaadus ar var atrast      |
	| Sun Feb 01, 2009 10:54 pm |     |
	| dlhawk Member of
			Pievienojies: 04 Jun 2008
			Komentāri: 1808
			2011  Alfa-Romeo  159 Ti
			Jācer ka šīs ir stiprākas nekā orģinālas savādāk nāksies daudz ko līmēt    |
	| Sun Feb 01, 2009 11:13 pm |       |
			Komentāri: 2329
			briest kaut kas tāds ?       |
	| Sun Feb 01, 2009 11:21 pm |     |
	| dlhawk Member of
			Komentāri: 1808
			Izskatās ka viens bokss būs jāupurē, lai ko šādu uzmeistarotu    |
	| Sun Feb 01, 2009 11:23 pm |       |
	| MartinsT Member of
	| Sun Feb 01, 2009 11:26 pm |       |
	| Presto
	| Mon Feb 02, 2009 9:33 am |     |
