krxzi
Pievienojies: 10 Jun 2007
Komentāri: 255
2003 Alfa-Romeo 156SW
 atskjiriibas starp 156 un 156 FL
tātad kādas vēl ir izmainjas face lift versijai iznjemot diizeljus jaudiigaakus un priekshas dizainu? aizmugureejaa optika ir taada pati? uutt utt utt..
| Mon Jul 02, 2007 9:25 pm |
Citāts:In April/May 2002 the facelifted version of the 156 was released. There are only minor
differences to the exterior. The most visible differences are the bumper inserts. They
are now body coloured and likewise for the side mirrors. The most oberservant will also see
the new (optional) Xenon headlights. On the inside, the changes are far more visible. The
steering wheel is just like the one on Alfa 147. The dashboard is slightly different at the
lower end and has new controls for the Aircon which now is a dual sone like on the 147. On the
upper dash there is now a new multi function screen that displays trip computer information plus
feedback on any faults and the action required. The selespeed system has also changed and there
are now handles like on the 147, not buttons like before. The engine program also changed a bit.
The 2.0TS engine was finally replaced with the all new 2.0 JTS engine which have 165 Bhp. You
can read more about the engines in the technical section on this page. Last, but not least the
Vehicle Dynamic Control (VDC) stability system is now standard across the range.
http://www.alfa156.net/fr_index.html?/history.html
| Mon Jul 02, 2007 9:32 pm |
2002. gadaa bija pirmais FL veel ar veco purnu. taa arii ir pati labaakaa 156
| Mon Jul 02, 2007 9:40 pm |
elbee rakstīja:2002. gadaa bija pirmais FL veel ar veco purnu. taa arii ir pati labaakaa 156
Kā nu kuram. es domāju Oga man piekritiīs
| Mon Jul 02, 2007 9:43 pm |
RAdikāli salons, man pēc FL salons nepatika.
Oriģinālais De Silvas dizains rullē
| Mon Jul 02, 2007 9:46 pm |
no 2002 gada nāca curtain airbagi virs logiem standartā, salons ar info ekrānu, brake assistant, krāsoti spoguļi un moldingi.
| Mon Jul 02, 2007 10:05 pm |
Gaumes lieta. De Silvas designs ārpusē ir ok. Lai gan man personīgi FL ar savu agresīvo purnu patīk daudz labāk. Ārpusē citu izmaiņu nav. Iekšpusē... Pre-FL priekšas panelis ir nu gandrīz tāds pats. Bet jaunās klimas pogas ir 984x labākas un viduskonsole vecajam vispār ir  Savukārt, ja vēl trāpās pre-FL ar melnajiem pulksteņiem, nevis baltajiem, tad tas jau izskatās pēc 1. paaudzes mazdas 3 un kāda nissana krustojuma. Bet, kā jau teicu, tas ir dziļi subjektīvi. Varbūt kādam arī patīk vecā iekša. Arbam piemēram pēc definīcijas patīk vecas lietas
| Mon Jul 02, 2007 10:07 pm |
Oga rakstīja:Gaumes lieta. De Silvas designs ārpusē ir ok. Lai gan man personīgi FL ar savu agresīvo purnu patīk daudz labāk. Ārpusē citu izmaiņu nav. Iekšpusē... Pre-FL priekšas panelis ir nu gandrīz tāds pats. Bet jaunās klimas pogas ir 984x labākas un viduskonsole vecajam vispār ir Savukārt, ja vēl trāpās pre-FL ar melnajiem pulksteņiem, nevis baltajiem, tad tas jau izskatās pēc 1. paaudzes mazdas 3 un kāda nissana krustojuma. Bet, kā jau teicu, tas ir dziļi subjektīvi. Varbūt kādam arī patīk vecā iekša. Arbam piemēram pēc definīcijas patīk vecas lietas
Ir lietas, kas man patīk jaunas
Bet savā būtībā es esmu pret FL.
Man patīk oriģinālas lietas.
| Mon Jul 02, 2007 10:12 pm |
man fl nepatīk tā sudrabaini krāsotā plastmasa salonā. Ja būtu izvēle ka vecajam - karbons vai koks - tad vēl ok, bet tas viltus alumīnijs atgādina AKAIM maģus no centrāltirgus gerkena veikala...
tas pats par klimatu - tas ir gaumes jautājums. vecajai viņš speciāli taisīts askētisks. Jaunaja - vienīgais pluss ir divs zonas.
bet kā auto - fl protams ir labāka.
| Mon Jul 02, 2007 10:15 pm |
Jā nu tā alumīnija folija biš sūkā. Bet salīdzinājumā ar "koku" Smica dīzelpowerī vai just to melnu garlaicīgo, kam nekā nav virsū, tā folija tomēr ir ok. Klimata pogas FL vēl līdz šim brīdim tiek uzskatītas par etalonu, no kā paraugu ņemtu daudzi, bet tad tā būtu atklāta špikošana. Tādēļ citi autoražotāji drusku kaut ko pamaina un... visu sabojājot, instalē vien savos spainīšos
Beigu beigās mūsdienās gandrīz jebkuram auto viduskonsolē ir alumīnija folija.
PS: par FL vs ne-FL un oriģinalitāti... FL parasti veic, lai veco uzlabotu un modernizētu nevis lai sabojātu.
Un vispār. Šis topiks draud ievilkties uz pusgadu. Alfistu viedokļi par FL vs ne-FL dalās pretējās nometnēs. 99% sadalījums notiek par labu savam auto - FL braucējiem tas liekas labāks. Pre-FL lietotāji mierina sevi ar domu, ka vecais, oriģinālais, ir vienīgais "autentiskais un pareizais"
| Mon Jul 02, 2007 10:21 pm |
| Mon Jul 02, 2007 10:35 pm |
hehehehehe
| Mon Jul 02, 2007 10:44 pm |
FL ir ļoti maz pārdošanā LV. Reti parādās. Šobrīt tikai viena ar 1.6 motoriņu tirgojas.
| Mon Jul 02, 2007 10:52 pm |
Nu var dabūt tak arī vienu SW Selespeed Distinctive. Bez 3 nedēļām gadu vecu un nepilnus 23k km nobraukušu
| Mon Jul 02, 2007 11:09 pm |
