Bosch L-Jetronic
wikipedia rakstīja:
L Jetronic (1974 - ca 1985) - analog electronic fuel injection. Uses a flapper-type AFM, or Air Flow Meter, to measure airflow into engine. A much simpler and more reliable ECU than D-jetronic, by use of custom designed integrated circuits. This type of air flow meter is called LMM, LuftMassenMesser, in all Bosch documentation. Used heavily in 1980's-era European cars [1]. Similar systems have been license built by Lucas and various japanese companies, but although their key components look similar to L-jetronic parts, those systems should not be called L-jetronic and parts are usually not compatible. The meaning of the letter L is disputed, either it stands just for Luft - air, or it might be just because it is the letter after K in the alphabet, and L-jetronic came immediately after K-jetronic.
Varētu būt tāds pats kā 75tajām ar att. motoru
skaties te:
http://alfisti.ru/164/164.htm
Pameklē te, domāju, ka tas nav vienīgais auto, kam likta šī šprices vadība.
Bildīte darbības principa ilustrācijai
Tik neprasi - kas ir kas.
