Atbildēt pie šī temata 13 lapa no 15 lapām pavisam
Iet uz lapu Iepriekšējais  1, 2, 3 ... 12, 13, 14, 15  Nākošais
Labākais auto ziemai?
Alfa Romeo 155 Q4 -> central epicyclic unit, Ferguson viscous coupling and Torsen rear differential
ta pati detala no otras puses
Citāts:
Figure: Lancia Delta / Lancia Dedra / Fiat Tempra / Alfa Romeo 155 4wd power distribution unit. 100% of the power goes to the planetary center differential (red), from there, the power is distributed between the front axle (yellow) and the rear axle (blue). When slipping occurs, the viscous coupling locks the front and rear shafts together. The engine is rotating the outer gear of the planetary gear center differential. Power to the front wheels is taken from the sun gear (center gear). Power to the rear wheels is taken from the planet gears (the smallest gears in the middle).
tur kāds traks inženieris ir skaitījis zobratus, caurām dienām SmileSmile
biski nesapratu  Crying or Very sad  vai tad bija ari 8 varstu turbo vismaz sitaja zimejuma ir tikai 8 varsti  hmm
arba rakstīja:
zato sitas poga ara visas syncro sistemas un looooti lidzinas vecajam labajam pirmajam quattro aparatam  Wink  ja ne pat labaks  Wink  yo
koijotins rakstīja:
tie vienkarsi Lancia zimejumi, vel ar 8v galvu
koijotins rakstīja:
skaidrite  Wink  shura
ko tā traktora viskomufta sabloķē - tikai priekšasi, vai arī centra difu pie viena ?
A bus station is where a bus stops. A train station is where a train stops. On my desk, I have a work station.
NIKSONS rakstīja:
ja es pareizi saprotu, tad mufta bloke centra difu, pakaleja tilta ir torsens, bet prieksejiem ritniem ir valejais difs. tad tai masinai vienmer griezisies abi pakalejie riteni un viens prieksejais. vai ari ta mufta bloke prieksejos ratus un centralais nemainigi darbojas ar attiecibu 44/56? tada gadijuma vinai visu laiku iet abi pakalejie riteni un viens prieksejais, bet tikko ka kads no prieksejiem riteniem izslid, mufta bloke priekstiltu un masina iet ar visiem cetriem, tatad klust par kartigu 4x4
ps: man sitas zobratu, muftu, saibu un sajugu padarisanas ir par sarezgitu  Embarassed
Cik nu es saprotu, tas sajūgs saklemmē priekšratus.
Starptiltu diffs paliek mūžam vaļā. Lai gan tas izpildijums ir īpatnējs - vārpstas ir viena otrā iekšā un tehniski arī tādas saklemmēt var...
NIKSONS rakstīja:
neviss ipatnejs bet italisks  shura
NIKSONS rakstīja:
 nono  Sabloķējas starpasu difs (When slipping occurs, the viscous coupling locks the front and rear shafts together)
Starp priekšējiem paliek brīvais didfs, un starp aizmugurējajiem līdz 70% bloķē Torsens
Drive to the front wheels is linked through a free-floating differential; drive to the rear wheels is transmitted via a 56/44 front/rear torque-splitting Ferguson viscous-coupling-controlled epicyclic central differential. At the rear wheels is a Torsen (torque sensing) rear differential.
Pēdējais no wiki par Lancia Deltu, un 155 Q4 had a 2.0 litre turbocharged engine and a permanent four-wheel drive powertrain both derived from the Integrale; it was essentially a Lancia Integrale with a different body
Tā arī nesaprotu, pārsvarā tā ir fwd vai rwd ?
AMV rakstīja:
AWD Wink
